Discussion topic: Sky mini box not recognising remote control
Message posted on 13 Apr 2023 09:15 AM
Sky mini box does start by pressing button on it manually but it will not recognise my remote. I have tried reactivating on the main sky q box and mini box. The remote allows me to turn on the tv and change volume but that's it. There is a communication issue between the remote and both TVs so perhaps remote is broken?
I have changed batteries and no different. I cannot use settings on mini box tv to check remote for the reasons above.
Any ideas?
Message posted on 13 Apr 2023 09:29 AM - last edited: 13 Apr 2023 09:33 AM
Re: Sky mini box not recognising remote control
Any ideas?
hi @Karl+Cov
Try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
The reset will also stop it working with yur TV until it is re-paired
Message posted on 16 Nov 2023 05:52 PM
Remote control not turning on sky box
