Discussion topic: Sky mini box not connected to tv
This message was authored by Keels This message was authored by: Keels
Hi. I've plugged every in. Connected sky mini box to tv but nothing is happening. Can anyone help please?
This message was authored by Chodley This message was authored by: Chodley
Re: Sky mini box not connected to tv
Can the TV display other sources ok?
is it on the right hdmi input?
is the power light on the mini green?
Hi @Keels
Reboot the mini as above.
