Discussion topic: Sky mini box issues
This message was authored by: Julian20
Sky mini box issues
Hi - unable to connect my second sky mini box and  first sky mini box is now regularly cutting out / losing connection to main Sky Q box. Possibly need an engineer to review house set up?
Re: Sky mini box issues
Hi @Julian20
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Avatar for Julian20
Thanks for your help here. Very much appreciated. I'll give that a go later on. Fingers crossed....... or call for an engineer after New Year! Cheers
