Discussion topic: New remote won't pair despite all instructions
This message was authored by: Catresidential
  • My original remote is broken, but still works even though the touch pad is hanging off. New remote won't connect at all. Been through all the above. So still using broken one
Re: New remote won't pair despite all instructions
@Catresidential
We have replied to your posts you created on a different discussion - you won't get any different answers here
BTW This duplicate post may be removed by someone
Unfortunately @Catresidential there is no indication on what you have tried.
To pair a Q remote the Q box must be on and the rrmote needs to be pointed directly at the Q box infrared sensor.
Avatar for Catresidential
I have tried all the online guides, sky guides, tips on this forum. Nothing is working.
Hi @Catresidential   Simple test, what happens if you press the "?" key. Does the led light up?
