Discussion topic: Sky mini box and remote not working
Message posted on 29 Apr 2024 05:55 PM
Remote does not work tv engineer checked it mini box stuck in stanby
Message posted on 29 Apr 2024 06:00 PM
Re: Sky mini box and remote not working
Sky remote and nini box stuck on standby checked by tv engineer and is not working
Message posted on 29 Apr 2024 06:04 PM
Hi @Andrea19661
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 29 Apr 2024 06:06 PM
Yes tested everything with a tv engineer reset the box used different remotes for other mini boxes in the house still not working
Message posted on 29 Apr 2024 06:30 PM
Hi @Andrea19661
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 29 Apr 2024 11:32 PM
Try pressing and holding 4+6 to turn it into an IR only remote (no voice control) then press and hold 1+3
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
