Discussion topic: Sky max
This message was authored by: Jackielou
Sky max
Whenever I watch sky max I have to enter my passcode.   Why is this ?
Re: Sky max
This is so aged restricted content can be broadcast before the evening watershed.
Re: Sky max
hi @Jackielou  as @caesarome  says, when SKY Max  & other channels show certain material before the relevant 'watershed' it will always be present & you cannot turn it off
https://helpforum.sky.com/t5/Sky-TV/Is-there-any-way-I-can-turn-this-damn-parental-control-off/ba-p/...
Do check that all the relevant options in Parental Controls are appropriately set but as I say you may need it for some
Our advice is set the PIN to something like 1111 to help enter it when needed
