3
This discussion topic has been answered Discussion topic: Sky listings incorrect
This message was authored by: Triedeverything
How do I contact Sky to report that the programming on one channel does not match up to the menu listings. It seems to be an hour off, and looks as if Sky went the wrong direction when the time changed. Now news channel CNBC shows are one hour behind the listings. I record programs on this channel and the recordings are always the program listed as being broadcast an hour previous instead of the program listed for that time. I would have to record the wrong program in order to get the correct one!
This message was authored by: Fothergill1 Answer
Re: Sky listings incorrect
@Triedeverything
That sounds really annoying.  You can report programme issues by sending an email to Viewer Relations at [email protected]
@Triedeverything
Avatar for Triedeverything
Thanks! I gave it a go, so we shall wait and see if they respond.
@Triedeverything  Your welcome.  The last time I reported something the acknowledged it fairly quickly.
