Discussion topic: Sky dish replacement cost?
Message posted on 07 Mar 2023 10:58 AM
If your sky satellite dish gets damaged will sky replace it for free, I have sky q?
Message posted on 07 Mar 2023 11:14 AM
Re: Sky dish replacement cost?
@zebman101 wrote:If your sky satellite dish gets damaged will sky replace it for free, I have sky q?
No, they are likely to charge to fix/replace it. (Only the Q boxes themselves are loaned/replaced)
Message posted on 07 Mar 2023 11:17 AM
Any idea of what the cost would be
Message posted on 07 Mar 2023 11:24 AM
Hi @zebman101 I have seen £65 banded about on this community. How did it get damaged?
Message posted on 07 Mar 2023 11:49 AM
The repair/replacement would be covered if you have Sky Protect or may even be covered by your home insurance. That said, I suspect it may by cheaper just to get Sky to fix it than pay any insurance excess.
You could also reach out to a local satellite installer, but again, you may struggle to beat £65 if that turns out to be the standard Sky charge.
sky Q | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 07 Mar 2023 11:51 AM
I think it got knocked by something but can't be sure
Message posted on 07 Mar 2023 01:48 PM
@zebman101Although Sky can charge it is pot luck if they do or not, call them out to fix it, they will be cheaper than an independent aerial installer and will have the correct meter to align the dish and replace the LNB if needed and leave you with a working system.
Message posted on 05 Jan 2024 06:18 PM
Had my broken dish replaced today free of charge😀
