Discussion topic: Sky card problem
This message was authored by: Fazer1000
Sky card problem
Sky card will not stay in the bix
Re: Sky card problem
Hi @Fazer1000   I'm afraid that you will probably need a new box. I would contact Sky.
@Fazer1000 just to check you are pushing it in to the slot as far as it can go when you do it should click into place
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
