Discussion topic: Sky box
Message posted on 10 Jul 2023 02:33 PM
Sky box
Where do I get the card for my sky box
Message posted on 10 Jul 2023 02:36 PM
Re: Sky box
@Chineze If this is a Sky Q box you should have gotten a card when you ordered Sky Q.
Can you confirm where the box came from?
Message posted on 10 Jul 2023 02:41 PM
Re: Sky box
When you first order Sky Q a viewing card is posted out to you to hopefully arrive before the engineer brings your Sky Q box and sets it up. If it hasn't arrived the engineer should have a spare.
If it's a replacement box that you've swapped on the doorstep you should have kept the card from your faulty box.
If you've acquired the box elsewhere it's basically stolen property you've bought.
