Discussion topic: Sky box
This message was authored by: Chineze
Sky box
Where do I get the card for my sky box
Re: Sky box
@Chineze  If this is a Sky Q box you should have gotten a card when you ordered Sky Q.
Can you confirm where the box came from?
Re: Sky box
@Chineze
When you first order Sky Q a viewing card is posted out to you to hopefully arrive before the engineer brings your Sky Q box and sets it up. If it hasn't arrived the engineer should have a spare.
If it's a replacement box that you've swapped on the doorstep you should have kept the card from your faulty box.
If you've acquired the box elsewhere it's basically stolen property you've bought.
