Discussion topic: Sky box
This message was authored by: Brihawk
Sky box
Hi how do I send back a sky package
Re: Sky box
@Brihawk
Do you mean a Sky Q box?
If you’ve cancelled successfully Sky should send out returns packaging near the end of the cancellation period, [31 days for Sky Q and 14 days for broadband], to the address that the subscription was registered at.
Note:~ If you’ve switched from Sky Q to Sky Glass the packaging is usually sent out after 31 days in case you change your mind about Glass.
You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
https://www.sky.com/help/articles/return-tv-broadband
If you haven’t anything suitable contact Sky again and see if they’ll re-send. Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
