7
This discussion topic has been answered Discussion topic: Sky Multi room issues
This message was authored by: Avidblue
Hello,
We have sky multi room in 2 rooms, one upstairs, one down.  Since we moved to sky fibre the one upstairs keeps on freezing with both live tv and also streaming on things we have recorded.
We have re-set the box a number of times, we have re-joined the internet and we have disconected it as well but the issue is still there and now we cannot watch any tv upstairs as its just not watchable.
Anyone else had this or know how to fix it.
Cheers
Abi
Re: Sky Multi room issues
@Avidblue wrote:
Hello,
Cheers
Abi
Hi @Avidblue
First try rebooting the main Q box and then when this is completely back up and running reboot the minis
Reboot the minis as above.
If the problem mini still does not connect try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini).
If the connected mini is nearer to the problem mini than the main box then you can try pressing WPS on the connected mini  instead of the main Q box
@Avidblue wrote:
Hello,
Cheers
Abi
Hi @Avidblue
Avatar for Avidblue
Level 2 icon
Thanks @oldfella that does appear to have worked 🙂
Is it quite common to happen with Sky broadband do you know?  We also have issued with the main box loosing lip sync, both issues have only started to happen since we moved to Sky for our broardband.  Wondering if I need to move to a better internet channel to stop it?
Shouldn't be issues due to Sky Broadband @Avidblue .
This message was authored by: Morrison+c
Still not working
This message was authored by: Invisiblename
@Morrison+c wrote:
Still not working
Sorry, but what is "still not working"?
I am just another Sky customer!
This message was authored by: S+Fallon
When I have all 3 of my multi boxes on the 3 one says to many boxes are in use
@S+Fallon
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
The original 1TB (non-UHD) Sky Q box only allows one mini to be in use. All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
