Discussion topic: Sky box issue
Message posted on ‎07 Jul 2024 10:30 AM
Sky box issue
The program we watch keep on freezing and it's take time to load a program
Message posted on ‎07 Jul 2024 10:41 AM
Re: Sky box issue
Hi @Ketan20 Have you tried power rebooting your box?
Re: Sky box issue
Hi @Ketan20
