Discussion topic: Netflix
Message posted on 05 Jul 2024 12:55 PM
Netflix
Why is my connection speed to Netflix only26 mbps and loading is slow
Message posted on 05 Jul 2024 01:27 PM
Re: Netflix
Poor wifi is likely to be the answer, if that's how you're connected.
Message posted on 07 Jul 2024 10:24 AM
Re: Netflix
dont think its the wifi because if i log on to netflix on just the tv and check settings im getting 46mbps but if i go through sky q box its only 26mbps so its cant be my wifi as its connected via hard wire to sky from my router but the tv is by wifi
Message posted on 07 Jul 2024 10:48 AM
Re: Netflix
Hi @Xeus37
If your Q box is on Ethernet and if you don't have any mini boxes have you switched off all the WiFi on the Q box.
Message posted on 07 Jul 2024 10:52 AM
Re: Netflix
ill have to check that later but thanks for pointing that bit of info out to me .will let you know at some point
