1
This discussion topic has been answered Discussion topic: Upgrade subscription message
This message was authored by: Liliya81
I've suddenly started getting a message to upgrade the account in order to access any menu option. But we have the subscriptions and it's been working  fine for years.
Any help would be appreciated.
Re: Upgrade subscription message
Hi @Liliya81
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Hi @Liliya81
