Discussion topic: Sky TV box
This message was authored by: Niria
Sky TV box
Hi, I want to book an engineer for home.
Re: Sky TV box
@Niria
You aren’t contacting Sky Customer Services by posting on here. This is primarily a customer to customer forum.
What Sky Q issue do you have and we can perhaps advise you?
Avatar for Niria
Re: Sky TV box
Can you give me Sky customer service number
Re: Sky TV box
@Niria
If you definitely need to call Sky you can call free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
Avatar for Niria
Engineer
I am trying to contact the customer service, but is not going. My TV box is stuck I want to book an engineer for home.
Re: Engineer
Hi @Niria
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Re: Engineer
@Niria
No need for a new thread. You asked this yesterday as well. You need to persevere on the phone if you need an engineer.
I asked you yesterday what the issue was but you haven't elaborated so we can't advise you on it.
Avatar for Niria
Re: Sky TV box
My TV box is stuck I can not connect
Re: Sky TV box
Have you tried rebooting your Q box @Niria ?
If you had to press the standby button on the front of the Q box (Amber led)  then try the following.
With the Q box on with green led try completly resetting your Bluetooth remote.
Avatar for Niria
Re: Sky TV box
Remote is not working as well
Re: Sky TV box
@Niria
Part of the reply from @oldfella outlines the issue with the remote. Try that first.
Re: Sky TV box
@Daniel0210 wrote:
@Niria
Box needs to on for that @Daniel0210
Avatar for Niria
Re: Sky TV box
It is still not working I have not been watching TV for 5 months I go to Manchester Andale to book an engineer
Re: Sky TV box
@Niria
Is there a reason you can't call Sky? Is it that there is a queue to speak to an agent?
Avatar for Niria
Re: Sky TV box
I am pressing in the numbers on the keyboard, but is not going then it is hanging off.
