124
This discussion topic has been answered Discussion topic: Sky Sports channel changing suddenly
This message was authored by: RMc4
On Sky Q box, only when watching Sky Sports, the channel changes suddenly to another Sky Sports channel.  Have tried taking out the plug of the Q box and waiting 5 (or more) minutes then plugging in again - no difference.  This only happens on Sky Sports.
This message was authored by: SpaceSparkie Answer
Re: Sky Sports channel changing suddenly
Posted by a Sky employee
Hi Everyone,
Sorry to hear that some of you are experiencing this issue. To help us look into it further, could you please provide the following details:
  • What Sky Sports channel were you watching when this happened?
  • What channel does it change it to?
  • Is it during the match, or adverts?
  • Have you experienced this on any other channel?
  • How far into the match were you, when it happens?
If you can, please also let us know the next time this happens.
I’m going to mark this as the answer for now so that anyone else experiencing the same issue can reply with the answers to these questions as well.
Sarah
Community Moderator
Hi @RMc4   I would rule out a problem with the remote by taking out the batteries.
This message was authored by: Yarcocanary
Sky Q Sports channel keeps changing to channel 402
My Sky Q box keeps defaulting to Channel 401,when watching other Sports channel
This message was authored by: LauraMac38
Re: Sky Q Sports channel keeps changing to channel 402
This message was authored by: whitecottageandy
I'm having this same issue!
Avatar for RMc4
I've tried taking out the remote batteries and the channel didn't change while I watched for half an hour.  Not sure if that is progress, but I've ordered a new remote from sky. I'll let you know if that solves it, but what I don't understand is , why does it only happen on sky sports channel.
This message was authored by: Aidan1965
I also have this issue.  It's annoying.
This message was authored by: EugeneM1
Likewise. It happens just on SkySports channels. Granted its only happened 3 or 4 times but it's a bit off putting all the same
This message was authored by: flipflop75
Having this issue, powered down and restarted box. Changed batteries in remote and still the same. Any answers
Hi Everyone,
Sarah
Community Moderator
Avatar for RMc4
Thank you Space Sparkie for joining the discussion.  My answers to your queries are:
  • Watching Sky Sports 405 or 406 when it happens.
  • Changes to 401.
  • Changes during the match, not the adverts.
  • Not experienced it on any other Sky channel.
  • It varies how far it is into the match when it changes, sometimes a couple of minutes, sometimes much longer.
I do hope this can be resolved.
This message was authored by: milish
Hi
we are having the same problem and only on Sky sports. When we switched on 401 and then change to 403 it bounces back to 401. It also switches if we changed from 403 to 401 it will bounce back to 403. This happens very regularly and it is so annoying. We have Sky Q. Can be as soon as we change the channel or within 5 minutes. Can be anytime in the ad break or in the middle of a match.
This message was authored by: Clerke
We are having the same problem.  Watching Chanel 403 and it switched back to 402.  This was the last Chanel selected but only for a few seconds.
hooebthis helps
E
I spoke with Sky technical support this evening and a lovely agent went through some settings with us and made some adjustments. While we were on the phone and for at least an hour afterwards it did not happen at all. Then it decided to flip again. So it went from 404 we changed to 403 then the TV went back to 404 itself again. My apologies I thought this happened during the ads but my partner tells me it is usually happening when there is a programme on not during the ads. I believe the lady we spoke with in Tech support was going to investigate this further and raise it. Hoping for a quick resolution.
Avatar for RMc4
I got quite optimistic yesterday when watching Sky Sports for ages and the channel didn't change. I thought that Space Sparkie has had solved it. But then it flipped channel.
I do hope we can get a resolution for this problem.
I did get a new remote from Sky but hoped I wouldn't have to go through all the faff of pairing it with my TV and sound system. So I'm holding off doing that in the expectation that Sky can fix this.
Has anyone else's channel changing been fixed?
Answered - Go to Answer
