11
This discussion topic has been answered Discussion topic: Sky Sports Plus Error
This message was authored by: Spitfire1000
Is anyone else getting this error trying to watch a game of Sky sports plus?
Re: Sky Sports Plus Error
Hi @Spitfire1000
Have you checked that you are on the latest Q software?
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
@Spitfire1000
While we wait for the image to clear moderation, which stream is it so I can test?
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Hi @Spitfire1000
Avatar for Spitfire1000
I'm trying to watch Charlton v Birmingham but it happens on every stream.
Sky sports football fine for the Wrexham game. As soon as I press the red button for match choice, the error appears. I can watch on my mobile app, but want to watch on the tv!
Any help appreciated!
Can see the image but I cannot replicate the error @Spitfire1000
You are not trying to watch a game that hasn't started yet are you? Think they are 7:45 kick offs.
Will check that now.
The Charlton game is definitely a 19:45 kick off.
The coverage has started though. Just checked the sky sports app on my phone.
Yep, I am watching on Q now without issue.
Have you tried the steps recommended by @oldfella ?
Or at least try a full power cycle on the box (unplug at the mains for 5 minutes).
Trying a software update now. Thanks for your help. Will see if that does the trick!
Hi @Spitfire1000
Assume you checked first that it isn't already on the latest version?
Next thing to try is to refresh the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
All sorted! Thanks OldFella. Was running ancient software probably!
