2
This discussion topic has been answered Discussion topic: Sky Q box failure
This message was authored by: Phil_55
Sky Q box failure
Q box failed, said I could try switching off to reset, tried several times with no success, had to scan the QR code on screen and reboot the hard drive which I did successfully but lost all my purchased movies, how do I get these back?
This message was authored by: Laing1 Answer
Re: Sky Q box failure
@Phil_55  if you goto https://www.skystore.com/ and login then go into my library you should be able to download them to your box again
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Phil_55
All sorted now, thanks for help
