Discussion topic: Mini box needs reconnecting each time
Message posted on 13 Aug 2024 07:08 PM
I recently recieved a mini box and managed to instantly connect it. However, once I've finished using and switch off, when I next turn on it asks me to go through the whole set up process again and to sync with the primary SkY Q box in the lounge (which is connected via Ethernet).
how can I prevent this dropping out? Thanks
Message posted on 13 Aug 2024 07:50 PM
Re: Mini box needs reconnecting each time
Hi @Haydo19
Assume you haven't turned the WiFi off in the main Q box?
Have you carried out a Network reset onthe mini?
