Discussion topic: Sky. Q upgrade
This message was authored by: Mal28
Sky. Q upgrade
Hello.im upgrading my sky q box so I can get the uhd package.just wondering can I keep my recordings or will I have to start again.
Re: Sky. Q upgrade
Afraid if you change your Main Q box then you will lose all recordings @Mal28
Any buy and keep from Sky Store can be downloaded to replacement box.
Re: Sky. Q upgrade
It is a full hardware swap so you will lose your recordings.
I would recommend making a note of any recordings you really want to see, then you can check on demand availability or for re-runs when your new box is up and running.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Avatar for Mal28
Re: Sky. Q upgrade
Thank you
Re: Sky. Q upgrade
@Mal28  If it is a box swap then don't forget to take out your viewing card from the old box before handing it over as you will need it for the new box
This message was authored by: Paul1402
Re: Sky. Q upgrade
Hi
How do you upgrade your sky Q box please ?
Re: Sky. Q upgrade
@Paul1402 wrote:
Hi
@Paul1402 you need to contact Sky
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
