5
This discussion topic has been answered Discussion topic: Sky Q touch remote does not work with the red button menu
This message was authored by: benster12345
When I go to the red button menu on the sports channels I get a menu to show me different options (eg. Different matches or golf tournaments). I am unable to scroll up and down to select different options with my sky q touch remote. Is there a way around this?
Re: Sky Q touch remote does not work with the red button menu
@benster12345 wrote:
I read on the community somewhere that if I go to the Home->Sport menu then in theory I can find the red button menu options there. So effectively I can still watch what I want to watch. Is that true?
Hi @benster12345
Cannot guarantee that all Red Button matches will be show in the Home - Sports menu.
However if you find them there then you can access them as normal.
Only Red button choices are affected by the remote issue.
Hi @benster12345
I assume this is the original touch remote without buttons in the central area. Unfortunately you cannot scroll with this version when using the red button.
Avatar for benster12345
Yes this is the original touch remote without buttons. Is there no way around this?
Afraid not with that remote @benster12345
Hi @benster12345
Answered - Go to Answer
