Discussion topic: Sky Q remote and lg smart tv problems.
This message was authored by: Cobey3289
I have a smart lg tv, less than a year old. Up until recently, my sky Q remote would control both my sky box and tv with no problems. However recently, I have had to re-connect through settings to use and pair the remote. Up until yesterday 24/11, it has found and paired the remote with one of the 15 settings in the sky system. Yesterday, I tried to pair the remote again, but none of the 15 settings would allow the remote to control the tv. I ran through the procedure twice with no luck. I then found the model number of the tv  (50 NANO 816 QA), I then input this into the system a couple of times with no joy. On each occasion, both with and without inputting the model number, I got the message, your tv is not supported!
How can a tv less than a year old not be supported now when it was clearly supported when I first purchased the tv? I could possibly understand it it had been my old tv which was coming up to 10yrs old.
So the big question is, how do I get my remote and tv talking again? Also, as seen in another post, from being able to switch tv and sky on through the remote and it would load sky up straight away. Recently, the tv would load all the lg channel information first, then I would have to tell the tv to use hdmi1 as the input source, even though this is the only source connected to the tv!
This message was authored by: Rally
Re: Sky Q remote and lg smart tv problems.
Oddly, ours started to do exactly the same yesterday having previously been set up by Sky engineer.
It's been suggested to try a different HDMI socket.
This message was authored by: MUHAMMAD6
Sky is not working
Northern skies signal
Avatar for Cobey3289
Ok, thanks for that. Currently recording the F1 qualifying. Once finished, will try that.
Still have same problem! Is it a sky problem or lg problem. Leaning towards the sky option......
This message was authored by: Rockyrambler
I also have the same problem which started a couple of days ago.  LG tv and sky remote volume buttons not working.  Has anyone had any luck resolving it
Lg tv and sky q remote
My remote seems to have stopped working with my LG tv.  It was working fine up until a couple of days ago but now the volume buttons and the voice control button no longer work.  I have tried re pair the remote but it reports that it is not compatible despite the tv being around 18 months old and has been working just fine for the last year.  Also tried everything obvious a  reboot and batteries.  Very poor if sky is no longer supporting a relatively new tv
This message was authored by: Nikki7508
I also have the same problem, been working fine for years and then all of a sudden the volume and mute buttons don't work. Thought it was the remote so ordered a new one, same issue. Now it just keeps losing connection with the box/tv. One minute the remote works, then it doesn't Also used to work with the cupboard door shut and now it doesn't.
This message was authored by: Anita73M
I am also having the same issue now. Was working but all of a sudden has stopped and it will not re-pair
This message was authored by: newby1
Just had the same problem as everyone
was very frustrating
tried all options online to no avail
had sky enginer call to day and fitted new q box and remote
all good so far
all good so far
This message was authored by: lol23
My sky Q remote for LG to now stopped working to is a new remote control and has worked since replaced but today none of the 15 codes work ridiculous this is the 2nd remote to do this
This message was authored by: AJT23
Jumping on an old message string.
Did anyone resolve this? My LG has just stopped volume control but I can still turn the TV on and off.
This message was authored by: 2Tarv
Mines also stopped working. Sky can you advise?
