18 May 2023 06:22 PM
Every so often, my picture starts to stutter, and I need to perform a software update on my Sky Q box to fix the issue.
Anyone have idea why this keeps happening? It can be every couple of days.
A software update always fixes the issue, and it never impacts the sky Q mini boxes, just the main sky Q box 🤷♂️
18 May 2023 06:42 PM
Hi @Kevin.1
Highly unlikely that performing a Software update solves your issue.
If already on the latest software then a manual update does not change the software and the box will just perform an extended reboot on restart.
A normal reboot will achieve the same result.
Suggest you try a Reset Settings in the Q box hidden menu.
20 May 2023 07:04 AM
Well, so this is weird. The picture was ok, but thought I'd follow the steps mentioned anyway.......once completed....the picture started stuttering again 🤷♂️
I performed a software update and the picture was then fine. (For how long is anyone's guess)
I clearly have a weird unique issue here!
03 Dec 2023 07:30 PM
That didn't work but all it managed to do is clear all my apps on the apps page.
thanks.
03 Dec 2023 11:46 PM - last edited: 03 Dec 2023 11:46 PM
@6OClock wrote:That didn't work but all it managed to do is clear all my apps on the apps page.
thanks.
I don't know who you were replying to but they'll reappear. They shouldn't have gone, that's a random glitch that sometimes seems to happen.
try a "Refresh Apps" to kick it into life in the installer menu.
04 Dec 2023 08:28 AM
Well, as the person who actually initially had this problem....I've not had the issue for ages. I worked out why....I was putting the sky box in 'standby' mode every night, and when i turned it back on in the morning the stuttering started. So I just don’t turn it off now, problem solved!!!
04 Dec 2023 08:29 AM - last edited: 04 Dec 2023 08:30 AM
@Kevin.1 wrote:Well, as the person who actually initially had this problem....I've not had the issue for ages. I worked out why....I was putting the sky box in 'standby' mode every night, and when i turned it back on in the morning the stuttering started. So I just don’t turn it off now, problem solved!!!
Hmm that shouldn't create that problem though, of course.
Did you also put it into Active mode instead of Eco so it doesn't turn itself off?
04 Dec 2023 09:46 AM
I don't have the problem anymore, so I'm not going to start trying things to break it 🤣
09 Feb 2024 08:09 AM
That worked for me, thank you👍
09 Feb 2024 08:33 AM
@TheyKnow wrote:That worked for me, thank you👍
Sorry, the forum doesn't automatically quote the post you reply to - what worked for you?
