Discussion topic: Sky Q not working
This message was authored by: MattWarden
Sky Q not working
Anyone else not getting any programmes through the TV guide? Movies are very slow as well. Have checked the router and done a speed test and all is well
Re: Sky Q not working
@MattWarden
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
