Discussion topic: Sky Q not showing tv guide
This message was authored by: NicolaGlanville
My skyq is not showing TV guide therefore you can't see what's on or schedule any recordings.
Re: Sky Q not showing tv guide
@NicolaGlanville
Have you tried a reboot of your Sky Q box? Come back to us if you don't know how. A reboot solves a multitude of little glitches.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Avatar for NicolaGlanville
Thank you for your reply how do I reboot the system please
@NicolaGlanville
Using the remote place the box into standby
Switch off the box at the plug
Wait at least 30 seconds
Switch back on at the plug
Follow the on screen prompts
When the screen goes black and the blue Q light goes out wait another 30 seconds
Press the 🏠 home button
Some items take 5 mins or so to return to normal.
edit: if your issue is with a mini box we recommend rebooting the main box, then when that's back up and running doing the same with the mini box. Also never carry out a reboot if you have no satellite signal as this causes problems.
Hi @NicolaGlanville   Put into Standby, switch off at the mains, plug wait 30 seconds and then switch it back on at the mains plug.
