Discussion topic: TV keeps going blank on record or live
Message posted on 27 Mar 2023 01:12 PM
My Sky Q box was fitted 2 days ago. Whether for recorded or live programmes the TV screen keeps going blank for a couple of seconds - no picture and no sound. Sometimes everty 20 minutes and sometimes every few minutes. While only off for a short time it is enough to lose information or the thread.
Message posted on 27 Mar 2023 01:15 PM
Re: TV keeps going blank on record or live
Hi @Jo1100
