3
This discussion topic has been answered Discussion topic: Sky Q network connection
This message was authored by: Hazzer20
Have Sky Q main box and then 2 minis, one upstairs and one downstairs, recently changed internet provider to ultra fast fibre in the property the signal isn't the best so I bought a decent booster that's connected to the WiFi that solves this issue, since moving internet providers the sky mini upstairs connection would consistently drop out I then switched all sky boxes to the boosters but now they all seem to cut out? I've put it back to the original set up but still the issue persists. Pulling my hair out trying to solve the issue. Any help would be appreciated
Re: Sky Q network connection
Hi @Hazzer20
Sky Q devices will not connect to 3rd party WiFi Extenders.  On 3rd party broadband you need to use a Sky Q booster between the main Q box and the minis.
First try the following.
Reboot the main Q box and then when this is completely back up and running reboot the minis.
Reboot the minis as above.
You will be asked to press the WPS button on the main Q box (not the mini as the Network reset will start the mini WPS automatically).  If you get the mini nearest to Q box connected then you can use this for WPS in the Network reset on the second mini (if it is nearer than the main Box)
Hi @Hazzer20
Avatar for Hazzer20
Oh wow thanks for your help, seems to explain it! I'm a little confused as to why only now the issue is happening when the connectivity problem has been fine for a good 2/3 months? Suppose I need to look into a booster
This message was authored by: Ad6
Absolute pain every single day with these Sky Q connection problems. Aswell as VPN issues with homeworking. Can't wait for this contract to end, utter tosh.
Answered - Go to Answer
