Discussion topic: Can't get any sky channels
This message was authored by: anitaSa
Message that appears is no programme spare currently being broadcast on this channel. Can anyone help. We have tried everything
Re: Can't get any sky channels
@anitaSa
Try rebooting your router by turning it off for 30+ seconds then back on.
Then try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for anitaSa
Hi this has not worked, I just says I check device power
Avatar for anitaSa
Sorry it says check device power
Avatar for anitaSa
Now saying
no programmes are currently being broadcast on this channel
@anitaSa  That will be a TV message not your Sky Q box.
"No programmes are being broadcast on this channel" is a Sky message usually seen when part time channels like BBC Three/Four are off air during the day.
Avatar for anitaSa
Anyone know how I can contact tech support at sky
@anitaSa
It would help if you told us the channel?
@anitaSa   You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
