This discussion topic has been answered Discussion topic: Sky Q mini box not working
Message posted on 18 Nov 2024 02:46 PM
We've moved the sky Q mini box and it's not connecting with the main box. Suggested we need a boaster box
Message posted on 18 Nov 2024 04:05 PM
Hi @Steve362
Reboot the mini as above.
Failing all of the above you may indeed need a Sky Q WiFi Booster to position midway between your main Q box and the mini and you will need to contact Sky directly.
Hi @Steve362
Message posted on 18 Nov 2024 08:00 PM
Re: Sky Q mini box not working
Thanks that's really useful advice. Kind regards
Message posted on 03 Jun 2025 10:24 AM
The sky mini box will not start after rebooting. Stuck with orange light on box
Message posted on 03 Jun 2025 05:01 PM
@PDP1 what happens if you press the orange light/button does it start up then if so then do the following
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 03 Jun 2025 05:09 PM
Mini box is temperamental.
Works and then doesnt.
Have to constantly reboot.
Believe the unit is broken.
Message posted on 03 Jun 2025 05:36 PM
@PDP1 when the mini box needs rebooting are you rebooting the mini box only or rebooting the main box first ? if you are not rebooting the main box first try doing that
Message posted on 03 Jun 2025 05:39 PM
Yes tried rebooting main box first still have issues. Need new box.
How do you contact an engineer?
Message posted on 03 Jun 2025 06:05 PM
@PDP1 You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
Message posted on 03 Jun 2025 07:27 PM
How do you phone sky if you arent on sky for phone.
Website takes you round in circles
Message posted on 03 Jun 2025 08:23 PM
@PDP1 click on the link i supplied and scroll down to need more help and click on that it will supply a number
Message posted on 03 Jun 2025 10:40 PM
Thanks will try
