11
This discussion topic has been answered Discussion topic: Sky Q mini box not working
This message was authored by: Steve362
We've moved the sky Q mini box and it's not connecting with the main box. Suggested we need a boaster box
Re: Sky Q mini box not working
Hi @Steve362
Reboot the mini as above.
Failing all of the above you may indeed need a Sky Q WiFi Booster to position midway between your main Q box and the mini and you will need to contact Sky directly.
Hi @Steve362
Avatar for Steve362
Thanks that's really useful advice. Kind regards
This message was authored by: PDP1
The sky mini box will not start after rebooting. Stuck with orange light on box
@PDP1 what happens if you press the orange light/button does it start up then if so then do the following
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
Mini box is temperamental.
Works and then doesnt.
Have to constantly reboot.
Believe the unit is broken.
@PDP1 when the mini box needs rebooting are you rebooting the mini box only or rebooting the main box first ? if you are not rebooting the main box first try doing that
Yes tried rebooting main box first still have issues. Need new box.
How do you contact an engineer?
@PDP1 You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
How do you phone sky if you arent on sky for phone.
Website takes you round in circles
@PDP1 click on the link i supplied and scroll down to need more help and click on that it will supply a number
Thanks will try
Answered - Go to Answer
