Discussion topic: Sky Q mini box not connecting
This message was authored by MFish75 This message was authored by: MFish75
Hi!
we've never had a great connection with our mini box but now it won't connect at all. We've tried resetting main and mini box multiple times. We get to step 2 of 4 and that's as fair as we can go. It seems to never recognise us pressing the wps.
any ideas on how we can get it working please?
thanks!
Re: Sky Q mini box not connecting
@MFish75 wrote:
Hi!
thanks!
Hi @MFish75
Reboot the mini as above.
MFish75
Thank you for replying.
we just tried all of that but still won't connect so will contact sky 🙂
Just to confirm @MFish75
Assume you are pressing the WPS button on another Q device and not on the mini you are trying to connect???
This message was authored by sallyann1964 This message was authored by: sallyann1964
I'm having the exact same problem with our 2 skq Q minis. Pressing the WPS on the main box and still not working. Have 2 useless boxes at the moment! Can anyone help before I get an engineer involved please?
This message was authored by DuncanBarr This message was authored by: DuncanBarr
Same issue. It started a couple of days ago and since then have had to reconnect my mini box every evening to my wifi. Now today had to do the same with the main Sky Q box.
The mini says its connected to the router but internet is not available, but internet connection is fine for every other device connected.
Restarted everything, re-added all devices and this does not fix the issue.
This message was authored by Stew123 This message was authored by: Stew123
Same issue here, hoping someone can help.
waiting for engineer visit in few days so will post if that delivers solution
