Discussion topic: Sky Q mini box not connecting
Message posted on 12 Feb 2024 04:26 PM
Hi!
we've never had a great connection with our mini box but now it won't connect at all. We've tried resetting main and mini box multiple times. We get to step 2 of 4 and that's as fair as we can go. It seems to never recognise us pressing the wps.
any ideas on how we can get it working please?
thanks!
Message posted on 12 Feb 2024 04:53 PM
							Re: Sky Q mini box not connecting
@MFish75 wrote:
Hi!
any ideas on how we can get it working please?thanks!
Hi @MFish75
Reboot the mini as above.
Message posted on 12 Feb 2024 05:18 PM
Thank you for replying.
we just tried all of that but still won't connect so will contact sky 🙂
Message posted on 12 Feb 2024 06:26 PM
Message posted on 27 Sep 2024 04:39 PM
I'm having the exact same problem with our 2 skq Q minis. Pressing the WPS on the main box and still not working. Have 2 useless boxes at the moment! Can anyone help before I get an engineer involved please?
Message posted on 27 Sep 2024 05:38 PM
Same issue. It started a couple of days ago and since then have had to reconnect my mini box every evening to my wifi. Now today had to do the same with the main Sky Q box.
The mini says its connected to the router but internet is not available, but internet connection is fine for every other device connected.
Restarted everything, re-added all devices and this does not fix the issue.
Message posted on 03 Dec 2024 10:24 PM
Same issue here, hoping someone can help.
waiting for engineer visit in few days so will post if that delivers solution
Message posted on 07 Dec 2024 07:49 PM
Exactly the same going on with my Sky Mini box. It's driving me crazy! Engineer booked for Tuesday. Hope you get yours sorted soon.
Message posted on 07 Dec 2024 10:02 PM
Engineers visit reconnected Sky Q to Mini - be careful to wait for all prior WPS attempts to complete before trying a second time or second connection (give it at least 5 but maybe 10 mins).
other than this the primary issue appeared to be driven by useless Sky Max Hub that would not hold connection to Sky Q - turns out that you should NOT use WPS connection from Max to Sky Q but should manually choose network in Sky Q (as per using a 3rd party router).
Hope this helps someone
