3
This discussion topic has been answered Discussion topic: Sky Q mini box need engineer to set up
This message was authored by: Tauriel
I am trying to contact Sky re:sky Q mini box set on old type TV set up in the bedroom, sky Q mini box is connected I just need an engineer to set this up.
Re: Sky Q mini box need engineer to set up
@Tauriel
I have removed your duplicate post. Two threads asking the same isn't required.
Is this your first Sky Q mini box? Did the engineer not set it up originally?
@Tauriel
If the television set is old enough to pre-date HDMI, you'll need to source a suitable cable:  the Nokia CA-75U is the one usually mentioned (assuming there's a component video input socket) and if it's a SCART-only set then you'll need a component to SCART block too.  I doubt Sky offers such things these days: they'll just say you need a more modern television.
Composite.
Component is YUV with red, green and blue phono plugs just for the video signal.
