Discussion topic: Sky Q mini box freezing and jumping - just been replaced
This message was authored by: teelula
My Sky Q mini box was replaced just before Christmas by an engineer as it was freezing and jumping on both live tv and recordings.
However the problem is still happening even with a brand new box. There are no issues with the main box only the mini.
I have an engineer booked again but what could the problem be? We've had sky for over 8 years in this house with no issues until recently.
Re: Sky Q mini box freezing and jumping - just been replaced
Hi @teelula
Reboot the mini as above.
Avatar for teelula
Thanks I've tried this numerous times as well as doing the system reset which seems to work temporarily but needs done 2-3 times in a row.
I don't understand why the problem as just started as nothing about the setup of my WiFi or broadband has changed.
This message was authored by: derekjp
After being at my wits end with the constant freezing and crashing, I called Sky and a very helpful Techie talked me through how to load the latest software version on the main and mini boxes. Fingers crossed but after about 10 days, the improvement has been dramatic. Not saying it will solve everyone's problems but it's certainly worth considering.
Interesting. They should update themselves but useful to know it's worth checking that and made such a difference. Thanks.
Knew I spoke too soon. My mini boxes, which have worked pretty much without any problems since reloading the software, have started to freeze and judder again. Could this be as a result of another overnight download by Sky which has screwed things up again.  Who knows?
No, updates to the Q software are very infrequent.
