18 Feb 2024 11:09 AM
Hi
My Sky Q box won’t connect to the router even after trying network settings. Extremely fed up of this.
Please help
18 Feb 2024 11:20 AM
@McDazzle wrote:
Hi
Please help
Hi @McDazzle
Are you carrying out a Network reset exactly as follows?
19 Feb 2024 10:42 AM
@oldfella wrote:
@McDazzle wrote:Hi
Please help
Hi @McDazzle
I have the exact same issue here.
Came home after a weekend away to discover that whilst my WiFi has been restored, none of my Sky equipment is talking to one another.
There is no "reset" option on the Sky Q box via those steps above.
You only have the option to connect to yoru Sky WiFi, another provider or a wired connection,
When I try to connect to my Sky WiFi it just times out as being unable to connect.
WiFi works on everyone other device in the house
19 Feb 2024 10:52 AM
@bhoyfett wrote:
@oldfella wrote:
@McDazzle wrote:
Hi
Please help
Hi @McDazzle
if you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.I have the exact same issue here.
Hi @bhoyfett
As I said in my post
"Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router
If you are on Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button."
19 Feb 2024 11:01 AM
Hi,
I tried that several times last night and this morning.
I even tried to connect to a different provider so I could at least explore whether my SSID would show up which it did but even then it wouldn't connect using the WPS button etc.
Since I wrote my previous post, I decided to press the reset button at the back of the router.
Although you said not to press this, it has in fact resolved the issue.
19 Feb 2024 11:25 AM
@bhoyfett wrote:
Hi,
Hi @bhoyfett
What I said was Do not press the reset button Instead of the WPS button when carrying out the Network reset.
19 Feb 2024 12:16 PM
Yup, I understand all that.
I was just saying that what you did say didn't work, but by pressing the reset button was in fact the resolution.
Cheers
19 Feb 2024 06:44 PM
Yeah, that's what I am doing.
it just won't connect.
had a really poor service for months now.
i have two sky mini boxes that keep freezing when watching live TV and only able to watch recordings on them randomly.
I love SKY but am contemplating having to cancel due to all of this. 🤦♂️
