7
This discussion topic has been answered Discussion topic: Sky Q mini box connection
This message was authored by: lomond82
Son has asked to pay for SKY multi room.
I am concerned that I'd be stuck with the 18months additional fees and it will not work.
where his room is located he has intermittent WIFI so he connects his Xbox with a "power socket adaptor" not sure if that's its technically name.
would a mini box work for him I don't want wires running from the dish to his room
Re: Sky Q mini box connection
@lomond82
A Q Mini box will function from a Powerline network adapter: if there's already a device using it then he'd need an ethernet switch as well.
It would be best to switch off the Mini box WiFi.
1) Press the ‘Home’ button on your remote control.
2) Scroll down to highlight ‘Settings’ but DO NOTpress select.
3) Press ‘001’.
4) Press ‘Select’
Then: Network -
- 2.4Ghz wireless - Off
- 5Ghz wireless - Off
Avatar for lomond82
Level 2 icon
I also forgot to add my WIFI is through VM as SKY broadband could only be provided through a BT line and constantly disconnected. BT replaced everything but it continued so after 3 years we moved the Broadband only
@lomond82
3) Press ‘001’.
4) Press ‘Select’
Then: Network -
Mini boxes don't have satellite tuners anyway, so can't use a dish feed cable.
Avatar for lomond82
Level 2 icon
Thanks @TimmyBGood
This message was authored by: RintelnHameln
Ok really sorry but I'm a complete non tech brain and trying to find my way hear:  I have:
a sky q and a new q-mini
we have non-sky broadband which goes by cable into the first point of a google mesh (first gen) and then by cable into to main sky q box.
the  google then forms a mesh with three other points around the house.  Both tvs in the house connect fine to the Google WiFi and stream Netflix, Amazon etc fine.  BUT Q MINI KEEPS FAILING - either finding then losing or just failing to find the main q WiFi all together.
i can't add a cable from the mini to a nearby Google point as they are first gen (speaker/boost but not a port for cable)
how do I ensure the mini connects to the original sky q ?
VERY PLAIN LANGUAGE EXPLANATIONS PLEASE 🙏
@RintelnHameln as Sky is not your broadband provider your mini boxes will not connect to your google mesh they will need to be connected to your main Q box.
When trying to connect them you should get a message on screen about pressing the WPS button on the nearest piece of Q equipment you will need to go to the main box and press the WPS button on that.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Joan1010
No it didn't.
have been trying to connect
by mini box for last 3 hours. Switch off router & back on again switched off
mini box rebooted everything still not working blue screen message problem finding your sky QBox
