Discussion topic: Sky Q loses connectivity
Message posted on 13 Oct 2024 01:04 PM
Ever since I have had Fibre 150 installed, my sky q box loses connectivity to the hub and now on serveral occasions the sky q box just shuts down, i do not have connectivity problems with my IMAC or tablets/phones
It now has lost more connectivity since Thursday 10/10/2024
Message posted on 13 Oct 2024 09:10 PM
Re: Sky Q loses connectivity
Have you tried resetting your Network? Go to Settings, then select Setup, then select Network, highlight Status and then select Reset on the right handside. If there is a problem, it will tell you how to Reset your Network.
This is just a suggestion. Good luck.
Message posted on 17 Oct 2024 10:17 AM
Thank you for that helpg=ful response but it is now stopping streaming from the sky q apps and just buffering thses apps and stating taht i have no internetc connection but everything else is working great, yet again for your for yoru jhelp in this matter
