Discussion topic: Sky Q issue
Message posted on
07 Mar 2023
02:40 PM
- last edited:
07 Mar 2023
03:39 PM
by
Kirsty+S27
Sky Q issue
I have the same issue, but i have Sky Q, have changed the HDMI cables and ports still have the same problem. Sky engineer came out and changed the Sky Q box no change. Samsung and twice remoted in and done diagnostics can't solve this, TV only 3 months old so went back to currys who said no issues with the TV it must be your sky q box??? can anyone help please
Moderator comments: amended title to include Sky Q
Message posted on 07 Mar 2023 03:14 PM
Re: Samsung S95B Sky Stream - Input Signal Plus Issues
Fantastic picture and TV......when it works....
Message posted on 07 Mar 2023 03:54 PM
Re: Sky Q issue
You haven't mentioned what the actual problem is?
Message posted on 07 Mar 2023 04:00 PM
Re: Sky Q issue
When i turn on the TV it says can't find Sky? although my sky Q is on? still the same if i turn it off and on. Then i have to go into Samsung Signal Input Plus and turn it off. Sky then comes on but defaults to 1080i, i try and change this in the sky setting to 2060 10bit but it say error, can only watch in 8bit? I then go back to samsung and select signal input plus for HDMI 1 and i can selct 10bit in sky Q? i have to do this every time i turn the TV on.......very frustating! I have tried 3 different cables and all HDMI ports.
Message posted on 07 Mar 2023 06:49 PM
Re: Sky Q issue
If your Samsung is 4k/UHD, there may well be a setting to force it to receive and display a 4k input from an HDMI source:
This is my Samsung set-up
Settings > General > External Device Manager > HDMI UHD Color > select the relevant HDMI port for your Sky Q box.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 08 Mar 2023 08:52 AM
Re: Sky Q issue
Hi, i used tio have that setting on my old Samsung and worked a treat, this tv S95B does have it, it has this Signal Input Plus that provide a better picture quality in 4K. this is the problem for the sky Q box i think.
