4
This discussion topic has been answered Discussion topic: Sky Q is not connected to the internet
This message was authored by: Bournemouth2
I have Sky Q and all today the tv has said you have no internet connection.
The only thing that doesn't seem to be working are the Apps and voice control.
 I have tried turning everything off and on again to no avail.
I have checked all the cables are in properly.
My i pad is connected to the internet.
Can anyone help please.
 I am not at all technical so if you have any ideas please give them to me simply.
Thank you
Re: Sky Q is not connected to the internet
@Bournemouth2 wrote:
Hi
Thank you for your really easy to follow instructions.
I have followed them to the letter but when I click on network and then across to:
Connect to sky Broadband Wi-Fi ( I have my own sky broadband router) and click on this nothing
happens and I don't get any more instructions?
Can you help further please
Hi @Bournemouth2
When you are in Settings and select Network you should see Status.
Go right with the remote to Status and you should see Reset on the right hand side.
Go right and select Reset
Thank you
Hi @Bournemouth2
Avatar for Bournemouth2
Hi
Hi
Hi @Bournemouth2
Brilliant,it has worked.
Many thanks.
