This discussion topic has been answered Discussion topic: Sky Q is not connected to the internet
Message posted on 20 Mar 2025 06:49 PM
I have Sky Q and all today the tv has said you have no internet connection.
The only thing that doesn't seem to be working are the Apps and voice control.
I have tried turning everything off and on again to no avail.
I have checked all the cables are in properly.
My i pad is connected to the internet.
Can anyone help please.
I am not at all technical so if you have any ideas please give them to me simply.
Thank you
Message posted on 20 Mar 2025 08:35 PM
@Bournemouth2 wrote:
Hi
Thank you for your really easy to follow instructions.
I have followed them to the letter but when I click on network and then across to:
Connect to sky Broadband Wi-Fi ( I have my own sky broadband router) and click on this nothing
happens and I don't get any more instructions?
Can you help further please
When you are in Settings and select Network you should see Status.
Go right with the remote to Status and you should see Reset on the right hand side.
Go right and select Reset
Message posted on 20 Mar 2025 07:34 PM
Re: Sky Q is not connected to the internet
Thank you
Message posted on 20 Mar 2025 08:08 PM
Hi
Hi
Message posted on 20 Mar 2025 08:56 PM
Brilliant,it has worked.
Many thanks.
