Discussion topic: Sky Q is freezing and red light in fron is on constantly
Message posted on 17 Oct 2023 10:10 AM
Hi. My Sky Q main box is freezing a lot and the red light on fron of box is on constantly. I've checked and there is nothing recording or queued. I've also done a soft reset. Is the only option left a hard reset which will lose my recordings?
Message posted on 17 Oct 2023 10:33 AM
Re: Sky Q is freezing and red light in fron is on constantly
Hi @Frolic
Depends by what you mean by a soft reset.
The reset Settings in the hidden menu is completely safe and will not lose your recordings.
Reset Settings in the Q box hidden menu.
Message posted on 17 Oct 2023 09:07 PM
Thank you @oldfella
Message posted on 17 Oct 2023 09:25 PM
Tried that - still got red light on constant.
Should I do a full reset with the other two reset options?
Cheers
Frolic
Message posted on 17 Oct 2023 10:03 PM - last edited: 17 Oct 2023 10:04 PM
Should I do a full reset with the other two reset options?Cheers
Frolic
Hi @Frolic
Unless it is causing issues it's not worth losing all recordings by carrying out a hard drive reset or Factory reset.
I assume that you have nothing recording or downloading in the background ?
You could try a reboot and instead of 30 secs leave your Q box unplugged overnight.
When you then Plug back in and switch your Sky Q box back on at the mains wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the Q box (Amber led)
Message posted on 18 Oct 2023 08:01 AM
Thank you @oldfella
Il will try this tonight 👍
Message posted on 21 Oct 2023 10:43 PM
Message posted on 22 Oct 2023 08:30 AM
If you have a continuous red light and tried a box power restart, the best option is to do a hard drive reset, as described here;
https://www.sky.com/help/articles/fix-recording-problems-on-sky-q-other-recordings-problems
