7
This discussion topic has been answered Discussion topic: Sky Q Mini constantly disconnecting
This message was authored by: K8bos
Sky Q mini refusing to connect to main sky box &/or network
nothing has changed in terms of set up have tried every re boot option possible multiple times including plugs out etc
started about 2 weeks ago and getting worse
Avatar for K8bos
This message was authored by: K8bos Answer
Re: Sky Q Mini constantly disconnecting
Engineer been and fitted a booster
all good
thank you
Hi @K8bos
Reboot the mini as above.
Avatar for K8bos
Hi
I tried that thank you, still no joy.
 Engineer now booked to investigate
many thanks
Avatar for K8bos
all good
thank you
This message was authored by: Sally66
We had this problem, the engineer came and replaced the box and left sky boost - it worked ok then the same evening, it started again not connecting.  It also keeps saying no connection to internet, but main box working fine, internet working - I just can't fathom what's happening
can the mini box be connected to the sky q box with a cable
@Sally66 yes it can but who is your broadband provider
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
It's now EE, it was Sky but it got so appallingly bad we changed provider
Thank you for your reply, so just to make sure I've understood properly (I'm not the brightest bulb), is it hard wire from Sky Q box to Mini Box or from Router to Mini box ?
Answered - Go to Answer
