9
This discussion topic has been answered Discussion topic: Sky Q hub settings will not activate
This message was authored by: Frickies
"Settings" although the box is highlighted it will not activate., I've tried two different controls and two different friends!  None of us can get it to work!
Re: Sky Q hub settings will not activate
@Frickies
So it's not a Sky Q hub, it's a Sky Q mini box.
Sky have suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Hi @Frickies   Does the Select (Ok) button work everywhere else?
Avatar for Frickies
Level 0 icon
Yes, until it gets to the option of "settings" and won't respond to "set up later" either
(and love your name, from Manfred Mann?)
Hi @Frickies   Sorry, exactly what "settings" are you talking about. You mention Sky Q Hub (which is a broadband router) but you have posted in the Sky Q TV community. I assumed you meant Settings on the Sky Q box menu.
Avatar for Frickies
Level 0 icon
Oh dear, it's my brother's Sky Q but he's even more clueless than me.  We have two televisions.  On 15th May there was an outage on Sky.  Through a friend's help we've managed to get his television up and working but the television downstairs (a hub box?) won't.  There is a screen (having pressed the appropriate connection button upstairs) which says "Accessibility on Sky Q" and at the bottom are 2 boxes, neither of which responds.
Avatar for Frickies
Level 0 icon
Our router is not Sky but were definitely connected as I just received a newer version today
@Frickies
Avatar for Frickies
Level 0 icon
Text boxes
"Settings"
@Frickies wrote:
Text boxes
"Settings"
@Frickies
See my post immediately above yours which is Skys recommended action for this.
Avatar for Frickies
Level 0 icon
Thank you so much.... 🌟🌟🌟🌟🌟🌟
Answered - Go to Answer
