Discussion topic: Sky Q - forever rebooting main and miniboxes
Message posted on 18 Mar 2025 11:24 AM
I have a sky Q box and 4 miniboxes, but am constatntly having to reboot them to get them to work. I had a couple of new main boxes last year but that still freezes on a regular basis. I have replaced one of my miniboxes but still have connection issues requiring a reboot an a regular basis.
Message posted on 19 Mar 2025 08:25 AM
Re: Sky Q - forever rebooting main and miniboxes
Message posted on 28 Mar 2025 11:18 AM
Sky Q equipment constantly needs rebooting
I have sky q and 4 miniboxes but have to reboot the main box at least twice a week and the miniboxes every few times I use them.
I went through the whole set up and reset my hard disk last week with SKY support through this forum, but the problems have continued and I've had to reboot the router now too
Message posted on 28 Mar 2025 11:30 AM
Re: Sky Q equipment constantly needs rebooting
Hi @Ballkop
Have you completed the following:-
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
If you are on Sky Broadband with the new Sky Max router then you need to consider this as 3rd party broadband
Message posted on 16 Apr 2025 03:44 PM
still having the same problems unfortunately
