Discussion topic: Sky Q cutting out
Message posted on 25 Jan 2025 10:20 PM
Sky Q cutting out
Sky Q mainbox and mini boxes keep cutting out without warning. Re-booting works for a while but then everything cuts out again.
Any suggestions for a cure to this?
Many thanks
Message posted on 25 Jan 2025 10:27 PM
Re: Sky Q cutting out
Many thanks
Hi @ARessa
Try a Reset Settings in the main Q box hidden menu.
