Discussion topic: Wifi keeps going off
This message was authored by: Alanridley
Wifi keeps going off 4 time with in the hour what can the problem be
Re: Wifi keeps going off
Have you tried completely resetting the connection @Alanridley ?
This message was authored by: Ronj
Get used to it more and more people are reporting this regularly,  you can try all the helpful remedies here but it's going to come back.
Worked here perfectly for years but now 2 or 3 times a week disconnects and  you have to go through the rigmarole of reconnecting Q then the mini - nothings changed with the broadband and alarms, lights, alexa's, tv, apps from all other services working perfectly.
So it's clearly Q at fault.
