5
This discussion topic has been answered Discussion topic: Apps not working
This message was authored by: Sue+LM
Apps not working
Watching a programme on ITVX yesterday. Screen froze then went blank. Now we can't access any apps (Netflix etc). Have rebooted SkyQ box to no avail. All other programmes are working ....help?
Re: Apps not working
Hi @Sue+LM
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Hi @Sue+LM
Select Apps 
Avatar for Sue+LM
@oldfella @Just tried this and it comes up with 'there was a problem refreshing your apps ' 🤷🏼‍♀️
Looks like your Q box does not have internet connection @Sue+LM
Try resetting the connection.
Avatar for Sue+LM
@oldfella Thank you so much! All up and running.....5* response!
This message was authored by: Kitts1
Hi I have the same problem,  have sky max router,  have switched off at mains etc, still saying no network connection please help, have lost all apps, Netflix,  you tube etc
