Discussion topic: Sky Q cutting out every couple of minutes
This message was authored by G.. This message was authored by: G..
Sky Q is cutting out every couple of mins when watching live and recording.
I have turned off at mains for couple of hours, checked cables several times, checked viewing card was in correct and dust free, there are no abstructions to satellite dish. I even reset the broadband.
I have also ran a software update.
LNB type is on Wideband (personal dish not shared)
I'm at a loss on what to do to resolve this issue
Any help would be really appreciated
Thank you 🙂
Re: Sky Q cutting out every couple of minutes
Thank you 🙂
Hi @G..
I assume the box is not excessively hot and is well ventilated and not stacked with other devices.
This message was authored by PandJ2020 This message was authored by: PandJ2020
Explain 'cutting out'.
Picture going black or something else?
I am just another Sky customer and my views are my own
G..
Thanks for reply so yeah screen goes blank for 1-2 seconds then continues with programme I'm watching
thanks 🙂
This message was authored by Chodley This message was authored by: Chodley
sounds like a dodgy cable
G..
You any idea what cable it would be?
thanks
G..
I will try this soon as I've finished watching bargain loving brits in the sun 🙂 thanks
G..
I am sky staff haha I just can't work out the issue
thanks
HDMI
sounds like TV is losing signal sync
This message was authored by DS150560 This message was authored by: DS150560
I am having exactly the same problem , picture goes black  & sound cuts out intermittently for a second or two , regardless of sky channel via satellite or app channel via internet. Did you resolve your issue and was it dodgy Cable?
DS.
